Video: Chimney Drain and Blanket Drain Under Dam/Levee
Version(s):08.11.09+
Area: Corridor Modeling
This video demonstrates how to construct a chimney drain and a blanket drain which begins where the chimney drain intersects existing ground and ends at a set distance back from the fill slope interception.
An example of the template can be downloaded here.
www.youtube.com/watch
