Comments, Questions, and Answers AutoPIPE Result Grids:
Item #1: Ability to export data to MS Excel or MS Access
Item #2: On the Code stress tab some of the combination results has the wrong units, example: from Result> Code Stresses> note units for PE Ring Def are inches.
Item #3: Input / Results grid are missing, reset location
Item #4: Can user control which columns to print in the "Reult Grid" mode? All I am interested to see in the print out is the first eleven columns (SEG to GlobalFR inclusive). Can it be done?
Item #5: Results grids, Code Stress Tab is blank
Item #6: Select Results> Code Stress> Stress, the color map for the Stress range is displayed with a floating dialog displaying information, What is Sustained (Max) and Rest-Fun (Max)?
Item #7: How to calculate the values for all the calculated values on the AutoPIPE Results Grid> Code Stresses tab> i.e. Stress, Allowable, Pressure, Bending, etc..
Item #8: Why is there no moment column on the Results grid - support tab?
Item #9: After using Save-As command, after some modifications, pressing Results grids directly displayed the results from the original file and not the updated file newly created, why?
Item #10: What does the Local 1, Local 2 and Local 3 columns mean on the Results grid support tab?
Item #11: Are the Results grids results in Local or Global coordinate system when using AutoPIPE?
![](f78e9d09473906909091861f536d43bf.iix)
