04. What Russian Codes (and ASME equivalents) can AutoPIPE be used for?
Product(s):AutoPIPE
Version(s):ALL;
Area:Report
Date Logged
& Current Version
April 2019
12.00.00.14
Problem:
Bentley AutoPIPE includes the latest Russian SNIP 2.05.06-85 for design of above and underground Oil and Gas pipelines has successfully been certified as meeting the Russian GOST standard. AutoPIPE has also been GOST certified as compliant with the following Russian standards:
  1. SNIP 2.05.06-85 - Above ground Oil and Gas Main pipelines
  2. SNIP  2.04.12-86 - Steel pipelines of water supply and the water drain
  3. SP34-116-97 - Designing, construction and reconstruction oil-and-gas pipelines
  4. CA 03-003-07 - Technological pipelines pressure less than 10 MPa
  5. PTM 38.001-94 - Pipelines at pressures greater than 10 to 100 MPa
  6. CH 550-82 - technological pipelines from plastic
  7. BH 39-1.9-005-98 - Sea, coastal pipelines
  8. RD 10-249-98 - pipelines of steam and hot water (ASME B31.1 equivalent)
  9. RD 10-400-01 - pipelines of thermal networks
  10. RD PTM26-01-44-78 - Technological pipelines pressure more than 10 Mpa
  11. 32388-2013 - Process Pipes (ASME B31.3 equivalent)
For this certification the user can use the appropriate ASME code
General FAQ about Piping Coden
