Significance of a dimension style that is in blue text or highlighted in blue when selected from the
 Product(s):MICROSTATION
 Version(s):08.09.00.92
 Environment: N\A
 Area: Dimensions
 Subarea: General
Significance of a dimension style that is in blue text or highlighted in blue when selected from the dimension style dialog box.
This indicates that a setting in the dimension style has changed and has not been saved. Once the dimension style is saved, the dimension style name will revert to black.
