A quick log can be created from a data grid or from the mapping interface.
To create a quick log from a data grid, select a row that contains the location to draw and select the option for Quick Log under the Grid Tools tab of the context sensitive ribbon. It is also possible to right click on the required location within the grid and select the option for Quick Log.
To create a quick log from the mapping interface, open the mapping by selecting the View Map option on the Mapping tab of the ribbon. A context sensitive ribbon will then appear allowing for further interactions with the map.
Select the Select Points option, then select the location from the map and finally select the Quick Log.
