| Product: | Ram Frame | ||
| First Affected Version: | 14.07.00.00 | ||
| Found in Version: | 14.07.00.00 | ||
| Released in Version: | 15.03.00.00 | ||
| Area: | Import/Export | ||
| Issue #: | 278310 |
A single frame can be exported to DXF, but when a second frame is appended to the dxf output Ram Frame crashes (RAMContainer MFC Application has stopped working).
New defect #278310 in v14.07
Fixed in version 15.03.00.00. For older versions export each frame to a different DXF file, then copy and paste or XREF those various files into one file.
