| Product(s): | Exor Core / Network / Asset Manager | |
| Version(s): | all | |
| Environment: | N\A | |
| Area: | Other | |
| Subarea: | N\A | |
How to clear your Java cache to allow changes to take effect.
- Open Control Panel on your computer.
- Select Java - this should bring up the Java Control Panel.
- On the General tab, under Temporary Internet Files, click the Settings button.
![](f74e3d141b710690f3fc5287624bcb0d.iix)
- In the Temporary Files Settings box that pops up, click the Delete button
![](9c5e3d141b710690f3fc5287624bcb96.iix)
- In the Delete Files and Applications pop up, make sure Installed Applications and Applets isn't ticked, then click the OK button.
- This will take a little while to run, then the Delete pop up will close. Click OK on the previous two windows to close them too.
External Links
Bentley LEARN Server
![](http://communities.bentley.com/cfs-file.ashx/__key/communityserver-components-sitefiles/TSG-Logo.png)
| Original Author: | Sarah Williams |
