| Product(s): | InRoads | ||
| Area: | Drafting | ||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
How do I label the bottom a manhole using the Place Profile Note command?
Manhole Bottom is not one of the values that can be annotated. However, a valid workaround would be to use:
({InvertOut}-{DepthBelowInvert})
This would assume that invert out is the lowest invert - and it usually is. The parenthesis behaves as a mathematical operator.
