The following table lists the fixes and improvements of OpenUtilities sisNET 2023 with version number 23.00.01.03, released on November 27, 2023.
Release 23.00.01.03 was built on PowerPlatform 23.00.01.339 and OpenCities Map 23.00.01.31.
The table is sorted by item ID.
OpenUtilities sisNET 2023 - version 23.00.01.03 uses the Object DB version 10.0.7. This is the same version as in sisNET 23.00.00.27, which was released in October 2023, but newer than the versions used in older sisNET CE versions. Upgrading to sisNET 23.00.01.03 from a sisNET version older than 23.00.00.27 therefore requires a DB synchronization
The sisNET 23.00.01.03 release contains the latest version of sisNET, sisFLOW, sisVIEW and sisIMS.
| Release Notes ID | New | Change | Bug | Description |
| 731439 | X | sisFLOW: The following functions have been released for DGN files that do not belong to the sisNET dataset (i.e. no job, pool, city or other file entered in the pool table): • FENCE DELETE - in the ribbon: Drawing/Start/Selection/Fence Tools/Delete fence content • DROP ELEMENT - Ribbon: Drawing/Start/Groups/Dissolve Element • DROP FENCE - Ribbon: Drawing/Start/Selection/Fence Tools/Dissolve Fence Contents • DIMSTYLE SET ACTIVE - Setting the dimension style of the MS element dimmension | ||
| 1279349 | X | sisNET: When creating iModels, date attributes were not transferred correctly. This has been corrected. | ||
| 1306834 | X | sisNET: The crash in some projects when creating iModells has been fixed. | ||
| 1306839 | X | sisNET: Variable definitions in the .siscfg files were not processed correctly if there were no spaces before and after the equal sign. This has been corrected. | ||
| 1309671 | X | sisNET: The preferences dialog (File - Settings - User - Preferences) opens without an error message. |
