| Version(s): | 08.01.02.15 | ||
| Area: | Text | ||
| Subarea: | Word Processor | ||
Editing text is asking for MS Office CD.
Every time text is edited with Word Processor I am getting prompted to
install Microsoft Office (from CD). I have to keep canceling it to add
text.
Product: MicroStation V8
Version: 08.01.02.15
Area: Text/Font
Refer to Microsoft solution below.
Reason:
Under a typical installation of Front Page 2000, the HTML Source
editing feature is set to install on First Use.
Note: You can also when browsing to a Web page that uses the DHTML Edit
control
http://support.microsoft.com/default.aspx?scid=kb;en-us;298110
The problem described is similar but not the same, however the solution
will correct the problem you are experiencing.
