| Version(s): | 10.11.00.115+ |
| Area: | Terrain |
Question:
How do I remove to foot apostrophe marking from my terrain contour text?
Answer:
This is controlled from the Master Units. Go to File > Settings > File > Design File Settings. Remove the tick (') from the Label for Master Unit. Hit OK. This will remove it in the Design Model.
