Product: |
OpenRoad SignCAD 2023 |
Version: |
23.00.00.151 |
Area: |
How-to |
Original Author: |
Bentley Global Technical Support |
An Image can be thought of as a grid of colored dots that provide a nice picture. The colors used on the image are not editable in OpenRoads SignCAD.
Step 1: Open the pdf in Adobe Acrobat Reader and use the Zoom Out and Zoom In tools or enter a scale percent to get the desired image size.
Step 2: In Adobe Acrobat Reader, pick Edit>More>Take a Snapshot and select the portion of the pdf you want to copy. The selected area will be copied to your clipboard.
Step 3: In OpenRoads SignCAD, create a new file or open an existing file to paste the image file into. Pick General>Paste.
Step 4: With the Element Selection tool, select the image and pick Properties. In the Image Properties, scale the image.
Step 5: Select and drag the image onto the sign panel and adjust object spacing as desired.
