Template Images
Many of the templates that are loaded into OpenGround Cloud Professional allow for the definition of one or more images to be placed on to a Quick Log. These are usually used to define a company logo and similar. To change the images, select the Template Images option from the Configuration ribbon.
The Template Images window will then appear. This window allows for a quick overview for what images are currently in use. To change one of these images, select the edit option next to the currently loaded image.
Browse through to the new image and click the save button. The new image will then appear in the Template Images window and also on the Quick Logs when next loaded.
