Help > Contents> Contents Tab> Reference Information> Code Compliance Calculations>
This area describes variables, equations, and methodology used by AutoPIPE to produce output reports per the code associated with the piping system database. AutoPIPE is capable of generating actual and allowable stresses for each of the applicable stress categories (depending on the current, analyzed load cases) for all codes listed below. Please Note: The Standard edition only has access to 4 ASME codes and European code EN13480 as shown in the Getting Started topic "AutoPIPE Standard vs Advanced vs Nuclear".
Select the Piping code hyperlink below for general questions about the code's calculations.
Note:
1. As indicated above, most of AutoPIPE's calculations are provide in the help documentation. Other more proprietary calculations are reserved for those that are apart of AutoPIPE's QA program (see here and contact QA Contract or Sales person for more information on the program). Companies apart of the QA program are able to audit the program and all calculations. Contact QA&R Program Manager or Software Quality Manager to schedule a visit. For all other request, they are handled on a case by case bases for the information being requested.
2. Additional hyperlinks are added below as new information is presented.
3. Allowable values are calculated based on code requirements. See the online help location mentioned above for details.
Example: Allowable calculation for ASME B31.1 (2012), "Stresses Due to Sustained Loads" category.
Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Reference Information> Code Compliance Calculations> ASME B31.1 (2012)> Stresses Due to Sustained Loads> Read the information, the allowable calculation is mentioned in the write-up.
"AutoPIPE reports sL, and the allowable stress (SH)."
The allowable calculation for this category is (SH).
In addition, other settings under Tools> Model Options> Results may affect the allowable calculations (i.e. Sustain Margin (Y/N/E), etc..)
4. If an AutoPIPE help calculation has a variable that was not defined in the immediate area, see Definition of Terms hyperlink at the bottom of the current help page. There are 8 categories of variables; select the correct category to find a specific variable with clear definition.
Code Name |
Description |
ASME B31.1 | Power Piping |
ASME B31.3 | Process Piping |
ASME B31.4 | Liquid Transportation Systems for Hydro-carbons, Liquid Petroleum Gas, Anhydrous Ammonia, & Alcohols |
ASME B31.8 | Gas Transmission & Distribution Piping Systems |
ASME B31.4 Chapter IX | Offshore Liquid Piping Systems |
ASME B31.8 Chapter VIII | Offshore Gas Transmission |
ASME B31.11 | Slurry piping code |
ASME B31.12 | Hydrogen Pipelines and Hydrogen Industrial Piping |
B31J | Stress Intensification Factors (i-Factors), Flexibility Factors (k-Factors), and Their Determination for Metallic Piping Components |
ASME BPV-III-1-NB | Boiler & Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components Division 1, Subsection NB, Class 1 Components |
ASME BPV-III-1-NC | Boiler & Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components Division 1, Subsection NC, Class 2 Components |
ASME BPV-III-1-ND | Boiler & Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components Division 1, Subsection ND, Class 3 Components |
HDPE - CC N-755-1 | High-Density Polyethylene |
JSME S NC1-PPC | Rules on Design and Construction for Nuclear Power Plants, Class 2 Piping |
BS806 | Design and Construction of Ferrous Piping Installations For and In Connection with Land Boilers |
SPC | Swedish Piping Code, Code for Piping in Stationary Plants (Stress Analysis - Method 2) |
TBK5-6 | Norwegian Pressure Vessel Committee, General Rules for Piping Systems |
STOOMWEZEN (D1101) | Dutch Piping Rule D1101 of the Rules for Pressure Vessels |
CAN/CSA-Z662 | Canadian Standards Association, Oil and Gas Pipeline Systems |
DNV | Norwegian Piping Code, Rules for Submarine Pipeline Systems |
MITI501 | Technical Standards for Construction of Nuclear Power Plant Components - MITI Notification No. 501 |
KHK Level 1 | KHK E 012 Japanese Piping Code for Seismic Loads, Level 1 |
KHKLevel 2 | KHK E 012 Japanese Piping Code for Seismic Loads, Level 2 |
EN13480 | EN 13480 European Standard for Metallic Industrial Piping |
RCC-M | French Piping Code |
SNCT | French Piping Code |
SNiP | Russian Trunk Pipelines Code |
BS7159 | Design and Construction of Glass Reinforced Plastics (GRP) Piping Systems for Individual Plants or Sites |
ISO 14692 | Petroleum and Natural Gas Industries, Glass-Reinforced Plastics (GRP) Piping |
General | General Piping Code |
- General FAQ's about Piping Code Calculations
