Log Reports are used to collate a number of Quick Logs together to quickly produce a collection of outputs for a number of locations all at the same time. Note that the following uses Report Profiles (a predefined list of the templates associated with a particular Location Type).
To produce a Log Report, follow the steps below.
Select the locations that are going to be reported (Multiple selections can be used by holding down the control button).
Select the Log Report option from the Grid Tools ribbon.
A blank report will then be produced. The Log Report Tools ribbon will open, this including a Profiles box.
Select the required Profile from the box (e.g., "My Profiles" in the example above) and the output will be produced.
