Product: |
OpenRoad SignCAD 2023 |
Version: |
23.00.00.151 |
Area: |
How-to |
Original Author: |
Bentley Global Technical Support |
Step 1: Open the image file in an app like Paint.
Step 2: Select the image and pick Edit>Copy. The selected area will be copied to your clipboard.
Step 3: In OpenRoads SignCAD, pick General>Paste.
NOTE: Press Fit View if you do not see the image on the workspace.
Step 4: Select the image and pick Properties. In the Image Properties, set the desired size by adjusting the Scale, Width or Height values.
