| Applies To | ||
| Product(s): | WaterCAD, WaterGEMS, SewerGEMS, SewerCAD, CivilStorm, PondPack | |
| Version(s): | 10.00.xx.xx, 08.11.xx.xx | |
| Area: | Output and Reporting | |
| Original Author: | Scott Kampa, Bentley Technical Support Group |
How can a user graph results for more than one scenario?
First, make sure that you have computed all scenarios that you want to graph the results for. Next, you will need to generate a graph. There are a couple of ways to do this. First, you can simply highlight the element or elements you wish to graph, then right-click and select "Graph". Second, you can go to View > Graphs, then select the New button and choose "Line-Series Graph". If you have not already selected elements in the drawing, a Select dialog will open allowing you to choose the elements you wish to graph. Using the second method will save the graph to the Graphs manager automatically.
Using either method will open the Graph Series Options.
On the right side of this dialog you can select the properties or results you wish to view. On the left is a list of scenarios that are in the model. Simply click the properties and scenarios you want to view and click Okay to view the graph. Note: The element you are trying to graph must exist in both scenarios.
