Product(s): | Promis.e, Bentley Substation | ||
Version(s): | through 08.11.12.xx | ||
Environment: | N/A | ||
Area: | Administration Features | ||
Subarea: | Setup |
During the creation of a parts database path, the following error message appears when the Next button is clicked to go to the field mapping step:
Warning
The database is used by another user.
This message has been found to occur when the default parts database paths, named "ansi-ieee_parts_database" and "iec_parts_database", have been deleted from the setup configuration. The only way to do this is by directly editing the setup.xml file since the [[Setup]] dialog does not allow these paths to be deleted.
This is a different situation than what causes the problem described in the [[Error - .MDB file in use or locked by another user]] article.
Do not remove the sections related to "ansi-ieee_parts_database" or "iec_parts_database" from the setup.xml file. There is usually no reason to directly edit the setup.xml file.
Make note of the settings on the [[Setup]] dialog.
Replace the setup.xml file with one from a workstation without the issue. The setup.xml file is located in the "Config" subfolder of the program data folder.
[[Program data folder - promis.e]]
[[Program data folder - Substation]].
Original Author: | Matt_P |
Kewords: TFS 146264
