Saving to dwg and Graphic Groups are lost
 Product(s):MicroStation
 Version(s):08.05.02.35
 Environment: N\A
 Area: DWG
 Subarea: Save
Saving to dwg and Graphic Groups are lost.
Product: MicroStation V8 2004 Edition
Version: 08.05.02.35
Area: DWG
AutoCAD does not support the MicroStation Graphic Groups, but does
support Named Groups. If a Graphic Group is turned into a Named Group,
and the Named Group toggle is on in the Save As dwg Options under the
Filter tab, the Named Groups will translate in the dwg format.
Other language soures
deutsch
