Product: | MicroStation | ||
Version: | 10.xx.xx.xx | ||
Environment: | N\A | ||
Area: | Cells | ||
Subarea: | General |
How to prevent a V7 Cell Library (pre-V8) from being upgraded in MicroStation V8?
Note - This functionality is only available 08.05.01.XX and later
Disable this functionality by setting this capability variable:
CAPABILITY_CELLLIB_ALLOWUPGRADEV7
For example, to disable this functionality in all workmodes:
_USTN_CAPABILITY > -CAPABILITY_CELLLIB_ALLOWUPGRADEV7
With this set the following message will display when trying to upgrade V7 Cell Libraries to V8 format:
A capability variable is preventing this action. These variables are defined in your workspace configuration. More information may be obtained from your system administrator.
Upgrading MicroStation /J Cell Library
Original Author: | Bentley Technical Support Group |
