| Version(s): | 08.11.09.292 | ||
| Area: | Cells | ||
| Subarea: | General | ||
| Original Author: | Marco Salino, Bentley Technical Support Group | ||
Place Standard Cells in a DWG file
How can a Standard - rather than Shared - Cell be placed in a DWG file
with Microstation?
When using Microstation in DWG workmode, all new cells are placed as
shared cells, since the DWG file format does not support normal cells.
In this workmode, you can also attach a DGN, DWG, or CEL file as a cell
library and insert its contents.
