| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Modeling |
| Date Logged & Current Version | Dec. 2016 10.01.00.09 |
Is it possible to simulate the free catenary for subsea / underwater pipeline using AutoPIPE?
AutoPIPE does not support large displacement and tension stiffening and hence should not be used for free catenary systems. It has been successfully for riser piping which is close to vertical for which such action is insignificant.
Model Subsea (Underwater) Piping
