| Version(s): | ALL |
| Area: | Modeling |
| Date Logged & Current Version  | March 2019 41.00.00.006  |
How can I input the bundle characteristics as existing, 20 spaces @ 250 mm (21 buffles), Fists to 279 mm, last to 213 mm using AutoPIPE Vessel?
You can set the distance you need from the tubesheet layout. In the tubesheet layout, there is a radio button to edit the longitudinal view. In this view, you measure distances and change the measured distance by double clicking on it.
Step -1
Step-2
Step-3
Then you will be able to define your baffle configuration.
