| Product(s): | gINT Logs, gINT Professional, gINT Professional Plus | ||
| Version(s): | 8.x | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
| Original Author: | Kathleen Holcomb, Bentley Technical Support Group | ||
Error on opening System Properties:
DialogControlsActivate.ActivateControl
Load List failed retreiving dialog number 32
Type mismatch
This error will occur if a color is missing a color number.
To fix this, go to Symbol Design -> Colors. Look for any colors that are missing a color number. Either delete the row or pick a color number for that color.
After saving you may get an error “Minimum allowed is 1”. Click OK. gINT will select a row where DXF Color Number is 0. Enter a DXF color number between 1 and 255.
