Product(s): | OpenRoads Designer |
Version(s): | 10.10.01.03 |
Area: | Workspace |
Original Author: | Holly Herring, Bentley Technical Support Group |
The presenter from Coffee Corner: OpenRoads - Setting Up Drawing Sheet Seeds in OpenRoads Designer uses an excel sheet to help organize and manage to different Sheet Seed creations. This contains a check-list as you go through and create the different Sheet Seeds to make sure you are setting all the required settings for each one. Can I have access to this?
You can download to excel sheet from the presentation here: RoadSheetSeedSizesScalesTemplate.xlsx. Here is another spreadsheet that can also be used: SheetSettingsExample.xlsx.
We also have additional training on the LEARNserver where these excel sheets would be useful. You can find that here: OpenRoads Designer Workspace Setup: Step 7 - Drawing Production Sheet Seeds
