OpenBridge Modeler allows setting the bearings directions related to the piers and abutments definitions or to the girders and deck. Initially, the user should have the Elevation Constraints for the Top Slope in the Substructure Placement set to Parallel to Deck, as shown in the screenshot below. Usually, the model will have the girders also already rotated, or aligned to the deck with some superelevation.
communities.bentley.com/.../rotating-prestressed-concrete-beams
