Applies To | |||
Product(s): | InRoads | ||
Version(s): | 08.11.07.615 | ||
Area: | Geometry | ||
Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
How can I annotate my Cogo points with the Cogo Point name only?
The cogo point annotation can be customized by editing the style associated with your cogo points. Select the cogo point style within the Style Manager, edit and then select Geometry Feature. Within Geometry Feature, select Points and check Point Name only within the Object column and then Apply.
