Product: | MicroStation | ||
Version: | V8 | ||
Environment: | N\A | ||
Area: | Text | ||
Subarea: | General |
What are the limitations of text (max number of chars) and max number of lines per text node?
What are the MicroStation V8 limitations on text elements with respect to the maximum number of characters and the number of lines of text within a text node?
The current limitation set on MicroStation text elements is 64000 characters.
The current limitation on the number of lines within a text node is 65535.
Original Author: | Bentley Technical Support Group |
