Applies To | |
Product(s): | AutoPIPE |
Version(s): | ALL; |
Environment: | N/A |
Area: | Analysis |
Original Author: | Bentley Technical Support Group |
Date Logged & Current Version | Dec. 2016 10.01.00.09 |
Should ZPA be applied when performing a Dynamic analysis with AutoPIPE?
When performing a Dynamic response spectrum analysis it is recommended to select "ZPA" option to capture maximum static or dynamic results. Also, Select "Missing Mass" to Capture additional Modal Mass beyond the Cut-Off Frequency.
Dynamic "Response Spectrum" Analysis
