At any time during the data entry process you can view the borehole log by clicking on the Quick Log button on the main Ribbon. This will display the quick log form and toolbar and give you access to all the log previewing features of the main OpenGround Cloud Professional application.
The default log that is displayed will be the default template setup for the location type in the main OpenGround Cloud Professional project/config pack configuration > manage templates (i.e., the same defaults that are setup for Quick Logs).
The Log Preview window can be moved to a second window if you prefer so that it can be easily refreshed and checked as you enter data into the profile.
