It is also possible to add documents directly to locations or their corresponding records directly within the Data Entry interface.
Press the View All option to view all of the documents currently associated with the current project.
Press the View Selected option to view the documents currently stored against the selected record.
Any record that has a document associated to it will have the document symbol in the farthest left column.
Press the Upload option to browse through to a file to upload to the database and associate it to the record.
Further information on Document Management can be found under the Document Management section of this guide.
