QUESTION: How can we export civil geometry form the design file to LandXML?
ANSWER:
Here are the steps you need to talk to export the geometry to a LandXML file:
- Open the design file that has the alignment and profile.
- Go to the Civil tab in the OpenBridge Modeler workflow,
- From the General Tools, click on the Import/Export pull down and select Export Geometry:
- Here you can select Export Type as LandXML and select the version that you want to export to. Toggle ON Only Active Profile to export the active profile along with the selected alignment to export.
- At this time follow the prompts
- Locate the Element you want to export, reset to end the selection, then left mouse click to select the LandXML version and one more data point to save the XML file.
