MicroStation
MicroStation enables you to model, document, and visualize infrastructure projects of any type, scale, and complexity using a comprehensive set of design and documentation capabilities to reliably deliver even the most demanding projects. You can also speed the production of detailed drawings and documentation, renderings, and animations. Additionally, you can reliably integrate any existing design content and work with any size team using virtually any mix of design applications. MicroStation enables you to develop and document better designs in less time by better connecting you to your tools, data, and teams.
