| Version(s): | V8i, CONNECT, 2023 | ||
| Area: | Line Styles | ||
| Subarea: | N\A | ||
| Original Author: | Craig Calvin, Bentley Technical Support Group | ||
Unable to change the Global Line Style Scale
Setting the Global Line Style Scale from the Design File Settings dialog is not retained if the Model Properties dialog has Line Style Scale set to Annotation Scale.
1. Open Models Dialog
2. Open Model Properties Dialog (Right-click on model > Properties)
3. Set Line Style Scale property to Global Line Style Scale & set the Global Line Style Scale Factor
Option 1: Model Properties dialog
Option 2 (V8i only): Design File Settings dialog (Settings > Design File > Element Attributes)
Option 3: Key-in ACTIVE LINESTYLESCALE <value>
Setting Line Style Scale In MicroStation
