Applies To | |||
Product(s): | AutoPIPE | ||
Version(s): | 2004, XM, V8i, CONNECT; | ||
Environment: | N/A | ||
Area: | |||
Subarea: | |||
Original Author: | Bentley Technical Support Group | ||
Date Logged & Current Version | Apr. 2016 10.01.00.05 | ||
Dynamic Time history analysis results are 0.00 in AutoPIPE output report,
Why?
In this case, it appears that the THL files with the model were manually generated by the user and some data may be miss-aligned. Following the steps below would resolve the issue and analysis can be performed with good results:
Incorrect Data
Time history load data is from another system
OK
After performing the steps above, results are now being displayed:
"Time History" Results in AutoPIPE
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
