Note:
a. User must be signed into CONNECTION Client before proceeding below, or have imported a license file with specific entitlements.
b. The same exact downloaded file is used by AutoPIPE Standard, Advanced, Nuclear, and all other language editions (such as Japanese, Polish, etc.). There's no need to download more than once. What functions and languages are available while using the software are determined by the license choice (ex. Standard, Advanced, or Nuclear) and program settings choice.
AutoPIPE will default to Demo mode when the application is first installed, the user must then change the edition setting on the "Welcome to AutoPIPE Licensing" dialog. This dialog will automatically appear when first starting AutoPIPE after being installed or as long as the "Show Welcome Screen on startup" checkbox is enabled in the lower left corner of the dialog.
Otherwise, use the procedure here to open the "Welcome to AutoPIPE Licensing" dialog.
Again, after opening the dialog the user must select an edition of the program to be used during the current Work session
(choose the appropriate radio button in front of the edition, Standard, Advanced, or Nuclear, to be used during this current session).
If it is not clear which option you should choose, contact your company's Bentley On-site Administrator(s) for assistance.
a. Features available when using an AutoPIPE Standard, Advanced, or Nuclear edition
b. Which edition to select on this dialog?
c. Which edition is currently being used?
e. How to review application release Notes?
Click OK to close the dialog an start using the program.
Notes:
a. To help with QTL invoices, when using AutoPIPE 11.x and higher, changing from one edition to another the first time will display the following warning message. Confirm available license in LMT. There is no way to limit licensing access to any edition of the software (Standard, Advance, or Nuclear); users must exercise restraint:
AutoPIPE Licensing
Please confirm the license change.
You have changed the license you wish to run this product under to
Nuclear. Depending on the license (s) your organisation owns and
product usage, this may incur additional software usage.
Yes No
More Questions:
Licensing issues outside of AutoPIPE
