Generating a Site Plan
To generate a site plan, simply select the Setup button from the Mapping Tools ribbon.
The map will then refocus to show a greyed-out border around the area that will be used for the site plan.
The map can then be dragged around to refocus the central area into the required position. To do this, left click and hold an area of the map and drag into the required position.
The scale can be adjusted to fit the area as required. Change the scale by typing directly into the Scale box or by using the slider to adjust the scale to the required scale.
Press the Lock to Map option to lock the visible area to the currently selected area. This then allows for the map to be moved around without the site plan area being affected.
The template selection option allows for different templates to be used when generating section templates. The mapping viewport will adjust to show the available space available within the template.
