| Product(s): | OpenRoads Designer CONNECT Edition |
| Version(s): | 10.12+ |
| Area: | Item Types |
Question:
When I place a civil element using commands (such as Line Between Points/Place Point/Arc Between Elements/Complex by PI/etc...) how do I show the Item Types in the dialog so that I can set the value as I place them?
Answer:
The following 2 variable control whether or not the Item Types will be displayed while placing civil elements:
CIVIL_TOOL_SETTINGS_OMIT_ITEMTYPES - Setting this variable = True will remove the Item Types from the dialog when placing a civil element. The value for the Item Types can be changed after placement in the Element Properties dialog.
CIVIL_QUICK_PROPERTIES_OMIT_ITEMTYPES - Setting this variable = True will remove the Item Types from the Quick Properties display.
Example with CIVIL_TOOL_SETTINGS_OMIT_ITEMTYPES undefined:
Example with CIVIL_TOOL_SETTINGS_OMIT_ITEMTYPES set = True:
