| Version: | V8i, CONNECT | ||
| Area: | Manipulation | ||
| Subarea: | N\A |
How to change all the Elements within a DGN file that have been assigned Attribute Construction Class to Primary Class.
1. Open the DGN file in MicroStation
2. Make the active Attribute Class 'Primary' (Use Key-In 'active class primary'
3. Use the Select All tool to select all the Elements.(Use Key-In 'choose all')
4. Enter the Key-In 'change class'
5. Enter the Key-In 'choose none' to deselect all the elements.
Note: the above Key-Ins could be used with the Batch Processor for processing multiple files
| Original Author: | Carl Myhill |
