AutoPIPE Forum - Soil - Virtual Anchor Length
Question
by
Nalin Subasinghe
Created in AutoPIPE Forum
Hi
I am modelling a DN900 undergriund HDPE pipeline.
When calculating Virtual Anchor Lengths I am getting La value less than 3xLb. Is it possible?
I am guessing it's because the E is low for HDPE compared to Steel.
If that's the case how should I assign the spacings in Zone 2?
Some numbers:
Pipe: DN900 HDPE 81.4mm thick
Pressure = 800 kPa
Temperature= 5 to 25 deg C
Soil - Stiff Sandy Clay
Ultimate longitudinal soil resistance, P1= 105,000 N/m
Transversr stiffness, K = 184
Lb = 1300 mm
La = 3000 mm
