Q1: Is there any way to determine natural frequency of Retaining wall soil numerical model from PLAXIS?
Q2: How can we see the exact element mesh size in PLAXIS?
Q3: I am using Mohr-Coulomb soil model and want to introduce constant Rayleigh damping of 3%.
Natural frequency of soil is 16.53 Hz, frequency of input motion is 5.0 Hz
I used ξ= 3 % for both Target 1 and Target 2
f = 16.53 Hz for Target 1 and f = 5/16.53 = 1.0 (closest odd multiple integer) Hz Target 2
w, α, β are calculated automatically but when I close Material window and edit material, all Rayleigh damping parameters ξ , f, w, α, β are reset to different values. How can I solve this issue?
Q4: How can we plot total vertical wall force on the wall vs time graph in PLAXIS? (Rigid retaining wall) See Pdf file attached
Dear Muhammad,
Here are some useful links:
https://communities.bentley.com/products/geotech-analysis/w/plaxis-soilvision-wiki/45568/plaxis-2d-tutorial-15-free-vibration-and-earthquake-analysis-of-a-building
https://communities.bentley.com/products/geotech-analysis/w/plaxis-soilvision-wiki/45510/simply-supported-beam
https://communities.bentley.com/products/geotech-analysis/w/plaxis-soilvision-wiki/45532/ground-response-analysis-in-case-of-linear-soil
https://communities.bentley.com/products/geotech-analysis/w/plaxis-soilvision-wiki/45533/free-vibration-analysis-of-a-dam
Note that the size of the generated elements will be according to the geometry and local refinements defined. The General information window, under Project menu, will give you some more details.
Note that the exact values of the α and β are stored directly in the material window while, the values for ξ, f and ω are only used to derive those (so not stored). When you reopen the material data set the shown values for ξ, f and ω as just another set of two points that computes the same α and β values. As long as the Rayleigh α and β are correct, there is nothing to worry.
If by total vertical force you mean the axial force of the wall, you can retrieve that using the feature Structural forces in volume plates. For more information on this PLAXIS Output feature, please check our reference manual.
Practically, with this tool, the structural forces are calculated by integrating the results in the stress points along the region perpendicular to the cross-section line.
Thank you so much. I have few more questions and send you my model in PM. Please have a look and reply. I will really appreciate it. Once again thank you so much.
