[ OBD U6 ] Can anyone inform me what " Processing Automatic Annotations " means ? I am getting this in the message box at the bottom of the screen when loading / opening a drawing.
In the message center after the " processing automatic annotations " message it has a yellow triangle with a ! inside it and informing me " automatic annotation processing took longer than expected! "
Can anyone give me any onformation about this , thanks
Hi Ben,
I will suggest you to go through the following Wiki. I believe this should answer your queries:
Regards,
Tathagata
