Hi,
I'm currently using ORD update 4 and trying to define a point from a template library. I added the template point definition (TL_Rail Maintenance Access Road) in the "Feature_Annotations_Levels_Elem Temp Metric.dgnlib"
However when I open the Template Library and try to change the point, I can't find my defined point that I've setup in the dgnlib. It always show the list as seen on below screenshot.
Where can I find the library that define the template points for the Template Library?
Thanks.
All feature definitions from loaded dgnlibs defined by variable CIVIL_CONTENTMANAGEMENTDGNLIBLIST should be seen in the list.
So check the one you've edited is included.
Screen captures show that TL_Clearance is not seen as well.
Check the expansion of the variable in File>Settings>Configuration>Configuration variables
