GeoStudio | PLAXIS Forum - Running Plaxis from Pycharm
Question
by
Farbod Yarmohammadi
Rising Star
Hi,
Im trying to run my plaxis python code using Pycharm and as soon as the code reaches "import plxscripting.easy", Ill get ImportError:
"ImportError: cannot import name 'MutableMapping' from 'collections' (C:\Users\Farbod\AppData\Local\Programs\Python\Python310\lib\collections\__init__.py)"
I saw in another question that we need to change the python interpreter in pycharm and choose the one in plaxis directory. But when I do that, pycharm tells me that the interpreter Ive selected is invalid.
I'm quite confused and I appreciate if you can point me in the right direction.
Cheers
Topics: PLAXIS 2D python
Accepted Solution
Dear Farbod,
Indeed, if PLAXIS is not running you cannot just try to start a new_server. The generic workflow would be to have PLAXIS running first, activating the server with a port and a password and then running your script.
If you want to skip this part, then as with any Windows application, Python can launch it using a different module. For instance:
import subprocess
subprocess.Popen([r"C:\Program Files\Bentley\Geotechnical\PLAXIS 2D CONNECT Edition V22\Plaxis2DXInput.exe", "--AppServerPort=10000", "--AppServerPassword=YourPassword"])
from plxscripting.easy import *
s_i, g_i = new_server('localhost', 10000, password='YourPassword')
# add your code here
