Is there a way to properly model and analyze (and hopefully design) shear walls constructed of CMU using RAM SS? I know there is a module in RAM Elements; is there some way to use the two software packages concurrently? What is the best practices procedure?
Thanks for any guidance! Learning more and more every day I use RAM but still quite the novice.
Cheers,
Keith
