MicroStation Programming Forum - Can't open MicroStation instance through VB.NET App
Question
by
Rob Golding
Contributor
Hi Everyone,
I am trying to create a stand alone VB.NET EXE application that simply opens up MicroStation, pulls some tag information and closes. I have created these types of applications before but not for quite a while so i must be a bit rusty.
I am having issues with the error messages stating "RPC Server Unavailable" and similar. I can also see that once the new Instance is called that nothing is showing in task Manager. So my question is what am i doing wrong for MicroStation not to open?
I have looked at previous projects and the below used to work, but for troubleshooting I have created a new, very bare application just to test this functionality to remove any other potential issues but still having the same problem. I have referenced the MicroStationDGN library in Visual Studio and imported the namespace. The entire code is below. At this stage i'm just trying to get MicroStation to open, then i will add the tag functionality into it once i know im on the right track. I can open MicroStation with no issues from the Start Menu so it is working normally.
The version of MicroStation on this test machine is V8i SS3 (08.11.09.292) - Yes i know its old, but its just the test machine.
Imports MicroStationDGN
Public Class Form1
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        Dim ustn As New MicroStationDGN.Application
        Dim odesignfile As MicroStationDGN.DesignFile
        Try
            odesignfile = ustn.OpenDesignFile("C:\Temp\rob.dgn")
        Catch ex As Exception
            MsgBox(ex.Message)
        End Try
    End Sub
End Class
