LARS | LEAP | OpenBridge | OpenTunnel | RM Forum - LB Concrete - Detailed Load Rating Results I
Question
by
Bentley Communities Legacy Member
Expert
Created in LARS | LEAP | OpenBridge | OpenTunnel | RM Forum
I need detailed Load Rating results, in this case for shear at each 10th point of PSC Girder for each design, permit and legal load rated.  I need to be able to see the VDL and VLL forces on the beam at each location (for each vehicle) as well as the corresponding shear resistance. (Ideally, broken out for Vc, Vs and Vp).  This is for a girder strengthening job where I will I compile these values in a spreadsheet and add the shear component from the CFRP wrap to determine the Load Rating results after strengthening.  How can obtain this information? Thank you.
