Hello
How do you assign a material to a terrain imported into openroads designer. I seem to do a lot of try and error before it works.. Can't seem to figure out the work flow.
Again how do you attach different material types to two different terrains in the same file...
I have tried using the assign materials tool but the two surfaces end up having the same material even after changing the terrain type or level.
Any help will be appreciated.
Thanks
