MicroStation Forum - Exporting DGN to Google Earth doesn't come up in the right place (SS3)
Question
by
Bentley Communities Legacy Member
Expert
Created in MicroStation Forum
Hi All,
I'm having an issue exporting DGN to Google Earth. I red all the other forums and did what others said as using the Geographic Coordinate System. I'm choosing the correct GCS but the line work doesn't come up in the exact place. It is usually shifted to the left 20-30ft.
I found a solution by using placemarks, but since I work in Road projects I have to place a lot of placemarks and it is time consuming.
The easiest way is just using the GCS from the library.  Maybe I'm doing something wrong here.
Anyone out there that can help?
Thanks!
