Hi,
Ive just started working on a small VBA project in Microstation V8i and am looking at trying to use XML files to help populate certain information within the programme. We are developing this within the "VBA Project Manager" of Microstation.
Currently i have a simple XML file in which i want to read an publish the information within the file to debug. Once i know i can get the programme to do this i can convert this for use in future tasks.
Below is the code i used which is taken from "Learning Microstation VBA" book. As far as i can tell this code is correct however when i try and run the programme i get the following error
Run-time error'91':
Object variable or with block variable not set
Private Sub XML_Load_Click() Dim myXML As New MSXML2.DOMDocument Dim myXElem As MSXML2.IXMLDOMElement Dim myXRecord As MSXML2.IXMLDOMElement Dim myXField As MSXML2.IXMLDOMElement myXML.async = False myXML.validateOnParse = False myXML.Load "C:\Users\ryan.grant02\Desktop\OLE_Wiz\Core_Settings.xml" Set myXElem = myXML.documentElement For Each myXRecord In myXElem.childNodes Debug.Print "***NEW RECORD***" For Each myXField In myXRecord.childNodes Debug.Print myXField.baseName & ".." & myXField.Text Next Next End Sub
The aim is then to convert this to allow me to complete multiple tasks such as populate a drop down menu, settings for the software, limitations of cells etc.
Any help on this would be appreciated.
